Hi,
I am hoping someone can help me with a slight problem. The crossfaders on the mixer work fine but with VDJ Pro the faders don't move in VDJ as I move the faders on the mixer. This has stopped working since I just recently downloaded the latest firmware update. Can someone review the setup I have below? Is there anything I am missing? Thank you!
2 deck external hardware mixer configruation:
For 2 deck (Left/right) hardware audio mixing using the hardware mixing capabilities of the DN-MC6000 via the middle two channels, set the following:
Set the switch on back of DN-MC6000 to INT MIX
Select USB/MIDI as the source for the middle two channels.
Press CF Mode to choose VIDEO.
IMPORTANT: Make sure that the AUDIO light is off, otherwise you will also control the internal software mixer of VirtualDJ and will not be able to headphone pre-listen from the MC6000. This is because the audio is faded out by VirtualDJ before it reaches the sound card of the MC6000 and its hardware mixer. Make sure that the software crossfader in VirtualDJ is always in the centre.
Alternatively, in VirtualDJ Pro you can disable the software audio crossfader in VirtualDJ itself by going to CONFIG -> Options and setting Crossfader to Disabled.
In VirtualDJ, go to CONFIG -> Sound Setup and set your sound settings as follows:
Inputs: Line INs
Outputs: External Mixer
Sound card: ASIO -> Denon ASIO Driver (Mac: 4-out card -> DN-MC6000)
Click APPLY
Presently at time of writing there is a bug in the DN-MC6000 firmware that will still send the position of the crossfader, volume sliders and EQ knobs to VirtualDJ at start-up in INT MIX mode, which may result in these not being in their default positions and affecting audio mixing via the real mixer in the DN-MC6000.
A work around is to go to CONFIG -> Mappers, choose the DN-MC6000 in the drop-down list and click + (Add.) Choose ONINIT in the drop-down list and enter the following in the Action: box:
crossfader 50% & volume 100% & eq_low 50% & eq_mid 50% & eq_high 50%
geposted Fri 10 Jun 11 @ 5:21 pm
In the above situation that faders won't move because you are using it in external mixer mode. If you want the faders to move you need to use the pcmix mode.
geposted Fri 10 Jun 11 @ 6:01 pm
Thank you DJ Cyder, I will try this.
Thanks,
DJ Noise (mliverno)
Thanks,
DJ Noise (mliverno)
geposted Tue 14 Jun 11 @ 8:16 pm
