thinking about buying one of these . ive been looking at getting another cheap vdj set up . ive looked at the numer dj2go but it doresnt have enough controls 4 me .
i was wondering if i get a midi controller without a sound card like the ctrl one , can i still cue mix (cue ---> masterout) i like to mix in the headphones alot not so much one ear mixing . i bought one of these cheap usb sound cards off ebay to check if its possible .with the usb sound card i can have that as the cue monitor for the heaphones , but when i move the cue mix dial nothing happens so im just wondering if you can do this . or do u have to be using the same sound card to cue mix (like in built ones on midi controllers )
basically i can have a master output (the built in sound card on laptop)
usb sound card as a monitor
but
i want to mix between the two in the headphones , i dont think you can do this though can you with two separte sound cards like this ????
cheers 4 any help
but
cheers 4 any help
geposted Sat 11 Jun 11 @ 6:13 am
I do this when setting cue points and planning out sets, I use the usb soundcard as my master out and the lappy for my headphones. It works for me. You shouldn't have any problems.
Huey
Huey
geposted Sat 11 Jun 11 @ 11:43 am
i dont think you can , i can set up vdj so that one soundcard can listen to the plf(the cue channel) , and the internal sound card outputs the master (or i can reverse this)
but the whole having one card as a master output and still being able to cue mix in the headphones in the other card(listen to both the cue channel and the master out through the headphones) i dont think you can do because your crossing between both sound cards
does any1 else know if this is possible
geposted Sun 12 Jun 11 @ 5:16 am
Yes you can........what do you think "Cue Mix" means?? I do it all the time with 2 soundcard, the usb I have the master running out and my internal I use as my headphones. Have you even tried it yet?? If you don't wanna use 2 cards then run it mono separated.........the choice is yours. VDJ can handle multiple soundcards.............
Huey
Huey
geposted Sun 12 Jun 11 @ 6:47 am
thanks 4 replying this is how i have things set up :
http://i279.photobucket.com/albums/kk134/Ryan_Guppy/vdjsetup-1.png
http://i279.photobucket.com/albums/kk134/Ryan_Guppy/vdj2-1.png
at the moment , i dont have a midi controller so just using the laptop (keyboard) . to get cue mix on controlllers i usually just remap a control/slider or whatever to headphone_mix . i just cant get it working with two separte cards not sure why . i think it might be that the cue button is acting as headphone volume not headphone mix on that skin , cant work out how to change it . usually have no probs at remapping when i have acontroller . i dont know what keys on the keyboard control the cue heaphone volume cant find it on the mapping list ggggrrrr
geposted Sun 12 Jun 11 @ 8:40 am
Ok try for your headphones choose "Primary Sound something" and see if that works. I know on mine if I choose the wrong one it won't work aswell. You might have map it but I don't think with the le version your allowed to do that.....
Let me know, we'll get it working :-)
Huey
Huey
geposted Sun 12 Jun 11 @ 9:00 am
thanks for your help , ive just tried a vestax typhoon with using 2 sound cards and it works fine . i didnt use the sound card thats inside the typhoon just used it as a midi controller , so yeah like you say it doeswork.so i can now go out and get a midi controller that i like :) i quite like the look of the gemini ctrl one . i will only being doing house parties if any so no point spending more money on a a controller with a sound card in .
cheers
cheers
geposted Sun 12 Jun 11 @ 11:45 am
