Forum: Old versions
Topic: rmx mapping
Hi all , just recently upgraded myself from the hercules console mk1 to the rmx and have made some changes with the 1-6 buttons adding a shift key (which used to be the scratch button) but now trying my best to change a few more with no luck.
installed a second hand copy of virtual dj 7 pro (did not want to buy new as i am only a bedroom dj)
what i am aiming for is to put a shift function onto the jog wheel so when i have a loop selected and if i have shift pressed it will adjust the length of the loop .. not as 1 to 2 to 4 to 8 but to whatever size i want it to be .. like a sliding action. was messing about with touchwheel and seen it did it but cant get it to work as a secondary feature to the jogwheel .. hope i explained that ok lol..
second thing i would like to do is make the treble left do effect slider 1 and 2 on left deck and right treble to do effect slider 1 and 2 on right deck .. can get it to do the shift and all but for some reason the left treble does left and right side of deck ..
any help guys would be very much appreciated ..
yours
justy
geposted Sat 11 Jun 11 @ 9:06 am
Sorry, but that is illegal.
Sorry, VirtualDJ licenses are non-transferable and cannot be sold, given or transferred to another user. Doing so is a violation of the End User License Agreement: https://virtualdj.com/atomixproductions/disclaimer.html
Please uninstall your illegal copy immediately and purchase your own legitimate license from https://virtualdj.com/buy/
Or use the Hercules DJ Console Edition if you have the CD for it.
Or use Home FREE with your mouse and keyboard only: https://virtualdj.com/download/free.html
Assuming that it is not second hand or the discount has not already been used, your RMX DJ Console entitles you to a significant discount off upgrading to the full VirtualDJ Professional. To receive this, please go to https://virtualdj.com/buy/ and enter your DJ Console software serial number in the box provided.
sorry did not know it was illegal to use second hand software ... well in that case i wont be using virtual dj then.. thanks
