Ive done a new windows7 install. Where the heck can I find the virtual vinyl soundcard drivers. It does not show at all. PLEEEASE HELP ME ASAP!!!!!!!!!
geposted Sat 11 Jun 11 @ 5:35 pm
http://www.numark.com/virtualvinyl
Documents & Downloads Tab
geposted Sat 11 Jun 11 @ 5:38 pm
I have that. Is it a special installation deal?
geposted Sat 11 Jun 11 @ 5:43 pm
There is nothing to install in the zip!?!?
geposted Sat 11 Jun 11 @ 5:49 pm
Why is this so difficult!!!!!!
geposted Sat 11 Jun 11 @ 5:53 pm
I cant find my disk. THIS F**KING SUX
geposted Sat 11 Jun 11 @ 6:08 pm
It installed I have no idea how.....THANX ANY WAY
geposted Sat 11 Jun 11 @ 6:10 pm
i know this is a bit late, but next time if something similar happens make sure your connected to he web and do
start> right click computer> properties> device manager > action > scan for hardware changes
and allow windows to search for the drivers.
also now the drivers are installed follow the above but once device manager is loaded, check the list for the device you are using and right click > properties > driver > device driver deails.
it will tell you which drivers are being ued and their location, seek them out in your ststem 32 folder and make a backup copy for future reference.
geposted Sun 12 Jun 11 @ 5:06 am
