I'm missing the search options for my music/video/karaoke. when i click on the "eye" icon to filter my search option, all i see is "show prelisten" & "show covers"....... WTF happened to the other items that go there? i cannot bring up any items but music. Can any one help?
geposted Sat 11 Jun 11 @ 9:44 pm
Check your Video tab in the Config. Did you Disable the video engine? If so, then VirtualDJ thinks you don't use videos or karaoke, so you don't get to search those items.
geposted Sun 12 Jun 11 @ 6:40 am
dunno if your issue is solved yet. double check that you've got stuff in your library and make certain you've got codecs listed in your codec list under your config screen. sounds like a glitched issue. if nothing else, uninstall/reinstall. if your windows is old and bloated that can often help.
geposted Sun 12 Jun 11 @ 8:32 pm
[quote=cstoll]Check your Video tab in the Config. Did you Disable the video engine? If so, then VirtualDJ thinks you don't use videos or karaoke, so you don't get to search those items. [/quote
THAT DID IT!!!!! I KNEW IT WAS SOMETHING SIMPLE! but i couldn't get it. thank you so much!
geposted Mon 13 Jun 11 @ 8:04 am
