Is it possible to import playlists from Virtualdj to iTunes??
geposted Mon 13 Jun 11 @ 8:35 am
All you need to do is,
1. Save your playlist in VDJ.
2. Open iTunes and click on any playlist.
3. Go to file, then library and choose "Import Playlist".
4. Go To: C:\Documents and Settings\ "Your Name"\My Documents\VirtualDJ\Playlists.
5. Find your playlist you saved in VDJ and import.
6. Once imported and highlighted you can play in iTunes.
7. Now this will work only on selected media that is in iTunes..
8 If not in iTunes, you can always import into iTunes what is missing & Re-do above steps...
Good Luck,
Joey....
Good Luck,
Joey....
geposted Mon 13 Jun 11 @ 3:34 pm
