I have the Hercules RMX and I was wondering how to set it up so I can attach different Iphones/mp3 players to play. I have all the cables i need, but once I hit play on my phone, no sound comes out.... what settings do I need?
thanx
thanx
geposted Tue 14 Jun 11 @ 7:49 am
When you're trying this, you DO have the RMX connected to a computer, with DJ software running - correct?
You need to plug your source into one of the INPUT RCA pairs on the rear of the RMX (make sure it's switched to LINE).
Then you need to press the SOURCE button (1 or 2 depending on which input you chose) and raise the volume slider for the channel you chose. You may also need to adjust the gain on the same channel, depending on the volume of your source.
Alternatively, read the RMX manual as stuff this basic should really be in there.
geposted Tue 14 Jun 11 @ 8:03 am
