Hi guys
since I´m currently unable to try one thing out with the vj function in vdj7.04 I thought to ask you,since you´ve probably used this. Is it possible to set a auto vj show if using the line in inputs from hercules console mk2,so that it´s soundcontrolled.
Let me explain,in 7.04 you´re able to set several inputs etc in the advanced audio config. How is one to set this up if to use the video functions in vdj so that the effects etc goes on a automated basis,with minimal user input.
Currently I´m at work,so if you don´t get what I mean,just let me know,I´ll try to make you guys a drawing of what I mean.
geposted Tue 14 Jun 11 @ 8:24 am
I believe what your asking is to activate several video effects with one key combination or command?
geposted Tue 14 Jun 11 @ 11:48 am
You can set up video to run automatically, just like audio. You can have the video transitions change automatically, using the random video transitions plug in. You can have the clip bank change clips automatically. However, you cannot scroll through the video or sound effects automatically.
geposted Tue 14 Jun 11 @ 12:08 pm
