I have downloaded some samples from download page. But for some reason not all of the work.. I assume that all the samples from vdj should work?? Anybody having the same problem?
geposted Wed 15 Jun 11 @ 4:56 am
Rename them with .mp3 at the end and they will work.
geposted Wed 15 Jun 11 @ 5:07 am
Are you trying to use them in the VDJ sample bank? If you are then they have .vdj after them. Playing outside of VDJ, then rename as above post suggested.
geposted Wed 15 Jun 11 @ 3:31 pm
get these too while ur at it:
http://www.mediafire.com/?tdfgmhg9j9of9r7
geposted Sat 18 Jun 11 @ 4:45 pm
Great Samples. Thx!
geposted Mon 20 Jun 11 @ 8:45 pm
