Hey All,
so I have a Numark Mixtrack Pro, and an Akai LPD8 triggerpad.
I have the pads on the Akai set to trigger the hot cues, but I want to program the knobs to manipulate the effects. The problem is figuring out the VDJscript so that some knobs apply to the left deck, and some to the right. Right now, if I assign a knob to, say, the Bass EQ, it will only effect the deck that is selected - select a different deck and it either doesn't work or works on the new deck but not the old one...
Any thoughts how I could assign knobs to only the leftdeck or rightdeck? Much thanks!
Regards,
DJ BDK
Regards,
DJ BDK
geposted Wed 15 Jun 11 @ 6:30 pm
you simply need to add the deck identifications before those actions (commands)
For example if you need to activate an effect to deck 1 ..
deck 1 effect "brake" active
or
deck left effect "brake" active
etc
So you will need buttons/knobs for each deck to trigger your actions.
or
etc
geposted Thu 16 Jun 11 @ 9:24 am
