hey guys,i need help selecting what to system to buy to make my powered speakers wireless.i looked at the line 6 g30,the vocopro air -net 2.4,the gemini uf 1264 but i dont know what to use.im trying to use a 4 powered speaker setup and looking to spend 400 -500 tops any suggestions welcome.doesnt have to be with the products i listed above
system setup below:
numark ns-6
2 gemini rs-410 highs (10 inch speaker)
2 mackie thump th -15a (15 inch )
system setup below:
numark ns-6
geposted Wed 15 Jun 11 @ 10:59 pm
Check Guitar Center or any large music equipment distributor, not sure if it's a good idea....
Good Luck,
Joey.....
Good Luck,
Joey.....
geposted Thu 16 Jun 11 @ 9:32 am
I'm not certain this is the best idea either as it leaves too much room for error. There are just too many wireless devices at any event that can interfere with the frequency that your speakers are running on. You will never have a completely wireless system as your active speakers need to be plugged into a stable power source.
geposted Thu 16 Jun 11 @ 9:51 am
I've thought of this on and off for a couple of years now
This is how I would do it:
I'd get 2 of these or something similar:
http://www.planetdj.com/i--SW77SGT
The receiver/transmitter stays close to me and the guitar antenna goes on the speaker.
I've never tryed this, but have used many wireless guitar systems since the mid 90's (when I played guitar for a semi-living)
I've always liked sampson & nady for that.
geposted Thu 16 Jun 11 @ 11:13 am
Hi mate.
Being a devils advocate type of guy. What do you hope to save on by using the wireless setup? You have to provide mains electrical power anyway so would the wirless system be a little over compex and expensive for the sake of 2 XLR cables?
Good luck with it but I think I could find better places for the money to go :-)
Just my thoughts
Daz
Just my thoughts
Daz
geposted Thu 16 Jun 11 @ 11:53 am
thanks guys ,everyones post help
geposted Thu 16 Jun 11 @ 7:57 pm
I use the Phonic wireless system and love it, used it last weekend actually.
Had two powered tops outside on a deck for a cocktail hour, it would have taken loads of wire and tape to make it happen otherwise.
http://www.bhphotovideo.com/c/product/711455-REG/Phonic_WM_SYS4_863_WM_SYS4_Stereo_Wireless_Speaker.html
These receivers attach to fly anchors on the back and I put internally wired outlets on the back to simplify the set up.
Also use wireless dmx and love it.
geposted Fri 17 Jun 11 @ 4:51 am
The frequency response is very poor on the Phonic wireless system... 50Hz to 8kHz (+/-3dB). Great lows, no highs unless it's an error in the specs. I am looking for something similar as I do many shows in hotels where I need a seperate system to play cocktail music in a different area or another room close by. Or need to place a speaker on the other side of a large room across from me. That can take easily 150 foot cable just to go 50 feet in front of me plus taping the cables at doors, etc. Any ideas for a good wireless system?
funkmasterfrank
funkmasterfrank
geposted Fri 17 Jun 11 @ 11:29 am
