Forum: Old versions
Topic: MacBook installation is not working
I tried to install VirtualDJ Home on my son's MacBook but we can not find the correct Macbook keyboard so we can not get the program to work with Vestax spin. My son is very upset so help me please.
geposted Thu 16 Jun 11 @ 3:45 am
No clue what this means? What do you mean, you can't find the correct Mac keyboard?
Sorry, VirtualDJ Home FREE does not support MIDI controllers such as Vestax Spin.
It is for non-commercial (Unpaid) use at home only, using your mouse and keyboard to mix: https://virtualdj.com/products/comparison.html
However, controllers can be tried for the first 10 minutes as a trial of VirtualDJ Pro features. After that, the controller will de-activate and control will revert back to mouse and keyboard only until you restart the software.
To use external controllers, you will need to purchase the full VirtualDJ Professional: https://virtualdj.com/buy/
If the Vestax Spin is not detected, make sure that you have the latest version of Home FREE from https://virtualdj.com/download/free.html
NOTE: Due to the fact that the Spin was never intended to be used with any other software, it may be detected as a Typhoon because both have the same firmware ID. This should not be too much of a problem because the Spin is very similar in layout to the Typhoon.
