Topic: mappers help please
i have the RMX and VDJ7 and i've heard you can swap the decks on the RMX to play all four decks from just the one controller. Can someone please help me on how to map my RMX to do this? all help is apreciated. thank you
geposted Fri 17 Jun 11 @ 3:58 pm
This was in another topic with pretty much the same concern and I just tried it out and it works perfectly! "Thanks to Patch N" Here is the link as well to refer too, that is if needed. https://virtualdj.com/forums/136256/General_Discussion/Loyal_Pro_user_impressed_with_Version_7_features_-_Too_bad_Hercules_wasn_t_better_informed.html
Best Wishes,
DJ Coach K aka THE MIX MONSTER
I have mapped mit LEFT and RIGHT Button on the RMX like this:
Button LEFT:
deck 1 select ? deck 3 select & deck 3 leftdeck : deck 1 select & deck 1 leftdeck.
Button RIGHT:
deck 2 select ? deck 4 select & deck 4 rightdeck : deck 2 select & deck 2 rightdeck.
So this mapping toggles between Deck 1 and Deck 3 each time you hit the LEFT button.
Same for Deck 2 and 4 with button RIGHT.
For you, if you would like to toggle between 1&2 and 3&4 the code should be like this:
Button LEFT:
deck 1 select ? deck 2 select & deck 2 rightdeck : deck 1 select & deck 1 leftdeck
Button RIGHT:
deck 3 select ? deck 4 select & deck 4 rightdeck : deck 3 select & deck 3 leftdeck
thank you very much! :D now i can get some practice using the 4 decks.
No problem, I been using 4 decks for a while and I was pretty much in the same boat as you, because I had to go to the laptop to switch the decks and now all I have to do is press a button and I'm off to the races, lol. It certainly opens up a whole new window of creativity for me.
Happy Mixing!
