Forum: Old versions
Topic: pitch control on herclues rmx
ok i just got a herclues rmx and the pitch control is off how can i fix it? i am ussing vdj 7.
geposted Fri 17 Jun 11 @ 5:04 pm
for example when i load a song and the bpm reads 127 and move the pitch just a tad it jumps to 127.39 or so instead of 127.1
Check your pitch range in CONFIG -> Options
The wider the range, the more course the adjustments will be.
For more accurate adjustments at wider ranges, you will need to upgrade to a controller with higher pitch resolution (14-bit)
The Hercules 4-Mx and 4Set both have twice as much pitch resolution as the RMX.
Other controllers such as Denon and Pioneer have even greater precision than this (8x for Denon DN-HC4500 and DN-MC6000)
Please see https://virtualdj.com/homepage/jpboggis/blogs/3759/MIDI_controller_pitch_accuracy.html for a technical explanation.
yes i also have the denon hc4500 and it is very on point.and i see the herclues rmx is not
