Gang -
Found the cause of some wigged out audio issues.
Apparently, some tracks were gain scanned and sometimes during my updates, the same name comes in and does not get updated - and as a result, plays at an incorrect gain adjustment. Usually too loud.
Did a re-analyze and fixed the problem on one track.
Right now, just highlighted the folder and telling VDJ to just rescan all those tracks.
Thoughts?
Thoughts?
geposted Fri 17 Jun 11 @ 7:22 pm
"Go to the Options tab and check if automatic gain is on AUTO"
"You can also automatically disabled Gain"
geposted Sat 18 Jun 11 @ 2:24 am
did ^ help OP?
geposted Sat 18 Jun 11 @ 4:45 pm
