do you guys know if I can use the two 1/4 inch outputs on the numark dj io as outputs so I can connect my speakers? and will this soundcard allow me to use my NDX800's in midi mode with my m3 mixer?
geposted Fri 17 Jun 11 @ 10:34 pm
The two 1/4 inch outputs located on the front of the dj io are for your microphone, with adjustable gain, and your headphones. It has RCA outputs for your sound system. So, the answer to your first question would be no, you would need to get an adapter for your speakers. This would come in the form of a 1/4 in stereo female to RCA male adapter cable, or you could use a coupler with a stereo male to RCA male adapter. The latter is easier to find at your local RadioShack, etc., at least in my experience. As for your second question, I have no insight. Hope this helps, and good luck!
geposted Fri 17 Jun 11 @ 11:05 pm
Please see https://virtualdj.com/wiki/DJIO.html
heres the link for djio connections mate
geposted Sat 18 Jun 11 @ 2:27 am
as above regarding connections annd yes you will be able to use your NDX800 with this sound card...
geposted Sat 18 Jun 11 @ 6:01 pm
you have to use the RCa to speakers...the frnt 1/4 inchers are as said above, for phones and mic.....REALLY good soundcard tho...I use it with a hercules control steel and a very average Acer laptop...perfect!!
geposted Sat 18 Jun 11 @ 11:58 pm
they do make cables that have RCA on one end and 1/4" on the other.....
geposted Sun 19 Jun 11 @ 2:03 am
