Is there anyway to program more than 3 hot cues into a track, or is there a skin available that lets you set more than 3?
Thanks in advance!
Thanks in advance!
geposted Fri 17 Jun 11 @ 10:44 pm
You can have unlimited hot cues assigned to keyboard shortcuts, controller or skin buttons.
Many skins have more than 3, just browse the skins section to find them.
geposted Sat 18 Jun 11 @ 5:50 am
Thank you!
geposted Tue 21 Jun 11 @ 10:33 pm
why not just press and hold ctrl on keyboard then hit number keys across the top of keyboard 1-9 then you can use Alt and the number keys to activate that hotkey.
geposted Fri 08 Jul 11 @ 1:27 am
Hi I'm using VDJ as well the udated Numark Mixtrack Pro version and I'm wondering the same thing...this program doesn't allow more than 3 hot cues...I have tried CTRL (#) and that did nothing...any ideas? Thanks!
geposted Tue 24 Jul 12 @ 1:09 am
you need to map it in first... It's just
hot_cue #
the # being the number of the cue you want to call eg.
hot_cue 54
you should register your version of pro so you have access to updates, effects and skins
hot_cue #
hot_cue 54
geposted Tue 24 Jul 12 @ 1:35 am
If you are using MixTrack Pro version of Cue LE or VirtualDJ LE then this is limited software - Please see:
https://virtualdj.com/wiki/How%20do%20I%20change%20the%20skin%20or%20use%20plugins%20in%20VirtualDJ%20LE%20or%20Console%20Edition.html
To be able to download and use skins with access to more than 3 cue points, custom map buttons on your MixTrack and much, much more, you will need to upgrade to the full VirtualDJ Pro at a discount: https://virtualdj.com/buy/
geposted Tue 24 Jul 12 @ 5:22 am
No it is working you just have to press and hold Ctrl button and press any numbers you want from 1 to 9
This buttons are on top of the letters buttons
it's FREE you don't have to be registered to be able to do this
geposted Fri 28 Jun 13 @ 4:52 am
