Topic: Numark DMC2
Hello I just purchased a numark DMC2 controller and I'm aware that it comes with the cue LE software. Is it this software the same as virtual DJ ? it appears to be but I'm not totally sure. I currently have the full version of virtual DJ 7 on my macbook pro if that helps.
Should I be able to run the DMC2 on Virtual DJ 7 ? what is the real different between the two ?
When it arrives do I just plug it in to my laptop and launch virtual DJ and it will automatically find it ?
thanks for any help you can provide.
geposted Fri 17 Jun 11 @ 10:56 pm
Virtualdj 7 Full pro has native support for more than 100 controllers currently, including the Numark Dmc2.
Cue LE can also be upgraded to virtualdj full pro at a discount.
Please register your serial of virtualdj full pro in your profile and download the latest version :
https://virtualdj.com/users/edit.html
If you have any issue or question about this please contact support :
https://virtualdj.com/contact/
You can see all the differences between LE and full version here :
https://virtualdj.com/products/comparison.html
