Doing a small custom button map on Hercules Control Steel controller....Both involve the Shift button, which I have programmed to control the shift function...The problem is mapping the other buttons to perform different tasks when the shift button is engaged......thanks for the help.....
My simple goals:
1. To have the "Pitch Slider" on the controller, DECK SIDE 1 to control "Pitch," and with "Shift" engaged to control the width of the "Filter Slider" DECK SIDE 1 on my VDJ skin.................Same thing on DECK SIDE 2...."Pitch" controls Pitch, and with "Shift" it controls the "Filter Slider" on the skin DECK 2.
2. I have 3 "Dry/ Wet Adjustment Knobs" for the chosen "Effect" on my VDJ skin.....I would like my "High, Medium and Low Control Knobs" ON THE DECK 1 SIDE, to control the High, Medium frequencies normally, and to control these 3 "Dry/ Wet Parameters" (Knobs on the skin), when the "Shift" button, ON THE DECK 1 SIDE is engaged..........and to do the same thing, control the High, Medium and Low frequencies normally, and to control the 3 "Wet/ Dry Knobs" when the "Shift" button is engaged, on the RIGHT SIDE DECK 2.
Thank you for your help...this VDJ script is a nightmare!!!.....I swear I only need these 2 custom mappings and I will never ask for another!....=D
My simple goals:
geposted Sun 19 Jun 11 @ 4:40 am
