Jog wheels not working on RMX
Can't set cue points, same on both computers.
7.3 on one and 7.4 on the other hower I use the same vdj folder (copied from one to the other hence problem on both.
Any ideas?
Any ideas?
geposted Sun 19 Jun 11 @ 2:17 pm
Are the jogwheels working outside of VDJ?
http://ts.hercules.com/faqs/eng/her_eng_00353.pdf
You've checked that they are not disabled in the DJ Control panel ?
geposted Mon 20 Jun 11 @ 7:39 am
lets deal with the worst outcome first... make sure you can set hot_cues just using a mouse, if you cant your database is probably corrupted and you better have a backup... If you can then your mapper/definition may be corrupted which isn't a huge deal, just open it in notepad to see if anything is missing, if it is just fill it in, you could also just ditch the one you have and get another from the download section.
There is a lesson i this though... anytime you update the database with lots of info on new tracks you should make a backup, but once a month should do, same goes for mapping before and after you play with it.
Good luck
Good luck
geposted Mon 20 Jun 11 @ 8:39 pm
