Hi there. Does anyone know of any good external VU meters that would work with my Hercules 4mx. The VU meter in vdj is really really bad. Doesnt even show you when your going in the red.
Any help is very much appreciated.
geposted Mon 20 Jun 11 @ 5:53 am
I use an external mixer with mine. One reason is I do not like using the mic input on the controller. it also gives you a meter.
http://www.prosounddepot.com/XENYX-1204USB-Premium-12Input-22Bus-Mixer-Prodview.html
geposted Mon 20 Jun 11 @ 7:22 pm
I also use an external mixer, the RMX sucks when it comes to mic output.....sounds muffled, and very low volume. I just ordered the 4mx, should get it Wednesday. Is the mic output any better with the 4mx?
geposted Mon 20 Jun 11 @ 7:30 pm
prob same as the RMX
geposted Mon 20 Jun 11 @ 7:36 pm
Dang!! Thanks djbojett. Oh well still waiting to play with it once it gets in. Thanks for the heads up!
geposted Mon 20 Jun 11 @ 8:52 pm
Yes it's better, it have more MIC gain ;)
geposted Tue 21 Jun 11 @ 5:05 am
