Is there a way to make VirtualDJ Pro Mac 7.4 remembers my advance soundcard setup, so that everytime I open the app It will be saved and I won' t need to open settings in VirtualDJ and press apply?
geposted Mon 20 Jun 11 @ 12:34 pm
That's curious. My VDJ installation has always remembered my config since...like...like forever.
geposted Tue 21 Jun 11 @ 6:39 am
I know my case is different because VirtualDJ treats the two Denon D-NS1200 players as two separate soundcards. Everytime I reopen VirtualDJ I have to go to settings and press apply.
geposted Tue 21 Jun 11 @ 3:55 pm
Yeah, I have the Denon DN-X1600 which is a single device, but even still I'm surprised to hear that. However, if indeed the problem is caused by using two sound cards, you might be able to solve it by combining the two DN-S1200's into one aggregate device.
geposted Wed 22 Jun 11 @ 4:38 am
I had the same problem, but then i got some sticky tape and labled my usb cables to there respective usb port on the side of my mac.. easy fixed
geposted Mon 27 Jun 11 @ 11:55 pm
That does not work even if I use the same usb ports.
geposted Wed 29 Jun 11 @ 9:56 pm
