Forum: VirtualDJ Skins
Topic: Dark Defaut (HD) - Page: 1
A skin i made a few months ago.
Looks like Virtualdj Default, but actually it has been created from scratch. Graphics are from Dark Minimal
I intend to release only HD resolutions, starting from 1600X900.
So i was thinking of 1920X1080 and another one that i need you to advise me.
Dark Default HD
Download Link
http://www.virtualdj.com/addons/13342/Dark_Default_HD.html
geposted Mon 20 Jun 11 @ 1:53 pm
awaiting release to download the skin
Uploaded
Dark Default HD
Resolutions : 1600X900
Working on 1920X1080 at the moment.
Update.
Added resolution 1920X1080 HD
So i will need one more HD resolution to add. Which will it be?
Close view..
looks great, just wish it was in 1440x900....
1366x768?
1920x1200 (Mac) ^^
Haui70 wrote :
1920x1200 (Mac) ^^
sounds good.
DJ azen wrote :
1366x768?
+1
Update
Added 1920X1200 (MAC resolution)
Pending review right now.
Downresizing to 1366X768 using the 1600X900 (same ratio) wouldnt be a problem. My initial goal was to add HD resolutions to the Skin Page, as they were only a few. Especially when a user wanted a skin that looked like the default.
1366x768 would be fantastic if you could oblige Bob.
Since selling the Macbook Pro I've gone back to being a low resolution DJ again :)
Keith
there are a lot of low resolution skins available. Lets make the HD and MAC users happier this time :)
Hi DjDad,
do you know if your skin will be available soon for download ?
moltes wrote :
Hi DjDad,
+1 Great Job Bob...
moltes wrote :
Hi DjDad,
No, i dont :)
Ok thanks for the answer. I'll be waiting then haha
either ive had a long day, or the Dark Default is hidden?? or still pending...
Do you have a link??? thanks (",)
DJDad,
I just wanted to give you a big congratulations on Dark Default HD. (Recently picked up a 23" 1900x1080 display.) I was looking for the best skin to meet the HD resolution and have deduced that yours to date is the best. Thanks man for the hard work on this skin.
Rick aka DJ Rxmx
djdad is there a way to change the rhythm view to a mirror wave. i have tried to do it but with no luck. either a Seperate mirror or overlap mirror rhythm. i know this is a old skin but i use it at a church i play for. like your work btw, thanks bro
83%
