I have a STEREO IO buy NUMARK and 2 NDX800's and a non usb external mixer (M3), what must my sound configurations be so I can use my external mixer and control VDJ with my NDX800's and so the sound comes out the output of my STEREO IO? Please Help! Thank You
geposted Mon 20 Jun 11 @ 3:59 pm
not sure, but this may help
https://virtualdj.com/wiki/DJIO.html
geposted Mon 20 Jun 11 @ 7:30 pm
no, but thanks for trying..
geposted Tue 21 Jun 11 @ 11:00 am
Hi guys
I use the Pioneer CDJ 400's with VDJ 7 Pro and it work perfectly well, except for the fact that it swop decks when I used the other sources like USB sticks and cd's. For example deck 1 on my left cd player will suddenly become deck 2 and vice versa. Then I have to configure it all over again.
Can anybody please help me in this regard.
Thank you
Thank you
geposted Tue 21 Jun 11 @ 2:43 pm
For advanced sound configuration like what you are asking for, you will need to purchase the pro version.
To diekoning, please start a new thread instead of hijacking an existing one. As to your problem, see my statement above. Or here is the verbage as it appears here: https://virtualdj.com/products/homefree.html
Designed for home DJs, VirtualDJ Home includes nearly all the features of VirtualDJ Pro, with only a few limitations.
If you don't own or don't plan to use any additional DJ hardware (mixer, turntable, DJ controller or video projector), then VirtualDJ Home will meet all your requirements.
geposted Tue 21 Jun 11 @ 3:18 pm
I am using the PRO version. That I have stated in my previous message.
geposted Tue 21 Jun 11 @ 3:28 pm
Then why haven't you registered your serial number here? Once registered, you get access to all skins, effects, etc. Until you are registered, most here will assume you are using a cracked version. I don't know about anyone else here, but I personally am not keen on helping a software pirate.
geposted Tue 21 Jun 11 @ 3:33 pm
Stereo IO only has a single stereo output, i.e: Only enough for 1 deck.
For two NDX-800's to an external mixer, you will either need 2 stereo IO's (One for each deck), or preferably one Numark DJIO which has two stereo outputs.
geposted Tue 21 Jun 11 @ 7:07 pm
geposted Tue 21 Jun 11 @ 8:29 pm
I'm very inexperienced and I know I'm going to sound like a complete idiot for this but...
I want to loop a certain section of a song. A 16 beat loop is too short and a 32 beat is just a bit to long. If I use the shift knob it brings in a part of the song that I do not want. Can someone teach me how to make a customized beat loop?
geposted Tue 21 Jun 11 @ 9:04 pm
I got everything to work I just got 2 stereo IO card and hooked them up to my NDX800 then to my mixer but no I have a diffrent roblem that has nothing to do with the above, Both of my NDX800 are reading that they are the same deck and i can't seem to change that... Any help?
geposted Tue 21 Jun 11 @ 9:13 pm
@ echo you would Prob get better results starting ur own thread
geposted Tue 21 Jun 11 @ 9:32 pm
Please open your own new topic on this subject.
To open a new topic, please click on the pen and paper icon at the top of the forum topic list page.
geposted Wed 22 Jun 11 @ 5:49 am
Please see https://virtualdj.com/wiki/Controller%20Configuration%20And%20Troubleshooting.html :
Decks inverted on MIDI controller (Left deck is right and vice-versa, or both control the same deck)
geposted Wed 22 Jun 11 @ 5:58 am
How do i get rid of the lag, I use 2 ndx 800s as midi controllers and when i want to scratch I get a bad lag, good for enough to use for mixing but not precise at all for scratching, the ndx800s work great when i switch to songs on usb or cd but in vdj they lag, ive tried setting latency to where it is no lag but its still there, i see no difference. Is there a way to get the controllers to be precise with the program? I've already stripped my pc, windows 7 to the bare components so nothing else is running in the background but vdj and neccessary programs.
geposted Fri 22 Jul 11 @ 7:29 pm
There is a tool you can download, but I'm afraid its only available to Pro Registered user. I had the same problem on my Mixdeck and now you can barely tell the difference between CD or use or MIDI.
Register your software and download it, you won't be disappointed
Huey
Huey
geposted Fri 22 Jul 11 @ 11:36 pm
