Ok, so I just got my controller and I need to know how to do prelisten. My laptops soundcard has 2 outputs, so i configured the left channel to be headphones and the right channel Master. Everything is set up the way it needs to be, I just need to know HOW ON EARTH DO YOU ACTUALLY PRELISTEN. Thanks in advance.
geposted Mon 20 Jun 11 @ 7:53 pm
geposted Mon 20 Jun 11 @ 8:08 pm
That doesnt seem to work. can someone explain step by step what to do? no matter what i try, nothing seems to work
geposted Mon 20 Jun 11 @ 9:38 pm
hi, check out my headphone setup and usage guide,
https://virtualdj.com/forums/108503/General_Discussion/Headphone_Setup_And_Usage_Guide_____.html?search=headphone%20setup%20and%20usage%20guide&page=1
hope this helps.
if your laptop has 2 outputs you gotta use the 2 soundcards setup.
simply setting your audio to output one on left and one on right will only play on one output.
hope this helps.
geposted Thu 23 Jun 11 @ 12:52 pm
