Hi everyone!
I saw this website called "Ustream" and it allows people to stream video and audio where people can watch them.
I want to do this but the only problem is that i can't figure out how to make the audio from the Denon MC6000 stream through Ustream so people can listen to it.
I hope somebody can help me!
Thank you very much.
geposted Mon 20 Jun 11 @ 9:50 pm
Broadcasting features are not available in the LE version of the software that you are currently using with your MC-6000. If you would like to use your controller and broadcast, you will need to upgrade to the Pro Full version.
You are entitled to a generous discount on your upgrade. Simply go to https://virtualdj.com/buy/ and enter the license key that came with your product in the box that says Upgrade to VirtualDJ Pro Full.
geposted Mon 20 Jun 11 @ 10:26 pm
Once your using Pro version, then you need a shoutcast stream to broadcast online. Most of the streams require a monthly subscription, but I've seen some that say free.... whether they work or not, who knows, you get what you pay for.
Once you establish a stream, you have to enter a server, port & pass into the broadcast config in VDJ.
Good luck in your search!
geposted Tue 21 Jun 11 @ 3:16 am
Thank you but Ustream is different its not like the normal streams where you put the IP and password. In Ustream you stream through a website, so thats why im asking
geposted Tue 21 Jun 11 @ 12:17 pm
From an output of the DNMC6000 go to the Mic input of your computer with a cable. Then with the computers built in mixer of the sound properties make sure you are getting that signal into the mix.
If you use UStream producer pro, its even easier, you select the mic input over there.
geposted Tue 21 Jun 11 @ 2:10 pm
