using VDj,and you need all your database from your PC ( cue,tags,BPM etc ) to be on your Macbook Pro.
1.Get a ex hard drive (it up to the size of music you have ).
2.Plug ex HD your Pc computer,then format it to( ExFAT ) not NTFS.
3.Make up a name for your ex HD after you format it.
4.Copy all your music file on to the ex HD the seem way as your music is on your Pc computer.
5.Open VDj on your Pc then go to the settings/browser ck the show desktop then OK.Now look for your ex HD you name and open some crates BUT DO NOT delete the info on you ex HD.
6.Eject the ex HD and plug it in your Mac and open VDj go to setting/browser and ck show volumes then OK and now look for your New ex HD with your music on it and open it up w/VDj.Open some crates and hit add to database then more crates.
7. Copy your ex HD on your Mac and do not delete the Pc info.Reopen VDj now look for you music you copy from your Ex HD to you Mac and add to favorites and your ( cue,tags,BPM etc ) are now on your Macbook Pro.
8.You can now log off VDj and eject the ex HD & go to your music/ex HD name and delete the Pc info and rename it.
geposted Tue 21 Jun 11 @ 10:54 pm
