....Not sure if this is normal...Dont think so but you guys might know....I go to MyDocuments - Virtual DJ Folder - Xml database....My PC immediately opens a Windows Explorer window and displays the Database....I cannot however scroll the page or exit from the window.....I have to open Task Manager and manually close out the application.....Tried reboot, safe mode all that.......Virtual DJ does run on my system NO PROBLEM though..............Im running a full Anti Virus, Anti Malware, and firewall.......All my scans come back clean.....Running an Acer Aspire 4G RAM, Dual Core.......Certainly this cant be normal????....
geposted Wed 22 Jun 11 @ 10:43 pm
right click it and open it with notepad of wordpad, by default it opens as html (read only). I also chose xml's to only open with notepad to save a bit of time
geposted Wed 22 Jun 11 @ 11:43 pm
...Boy do I feel like a Dumb A$$....lolol....Ya notepad works fine.....I feel sooo dumb, I work in the IT field as a "professional" and I didnt realize I was in a Read only file!!!.....ha.....thankx for the help my friend!...... =D
geposted Wed 22 Jun 11 @ 11:52 pm
Internet explorer has terrible XML parsing capabilities, that same file will open just fine in Firefox or Chrome if you like the 'pretty' view.
geposted Fri 24 Jun 11 @ 4:58 am
