Hey,
I just bought a nanopad2 and I'm trying to figure out is it possible to load my cue loops and effects on it..
If yes, how?
Thanks
Dj Lil'R
If yes, how?
Thanks
Dj Lil'R
geposted Thu 23 Jun 11 @ 6:33 pm
Yes, it is possible. You'll have to use the Config-->Mappers tool to MIDI-map the desired function(s) to your Nanopad2.
geposted Fri 24 Jun 11 @ 6:45 am
Go Here download mapper, follow instructions https://virtualdj.com/addons/8391/Korg_NanoPad_Def___Mapper.html
Good Luck,
Joey...
Good Luck,
Joey...
geposted Fri 24 Jun 11 @ 7:07 am
