When I tried on the 20days trial of VDJ LE to VDJ PRO It freezes when I turn the knob of "CUE MIX" and "CUE GAIN" on the mixtrack pro controller. Can you guys have an idea why this happens and is there a fix for this? Thanks!
geposted Fri 24 Jun 11 @ 3:04 am
if you havnt already, pop over to numark and get the latest drivers, chances are the drivers are outdated due to coming on disc with the controller and you need to install newer ones for use with pro.
just a thought.
other than that, pro does use up a lot more system resources so your cpu might be struggling to cope, do some tweaking on your computer and get rid of all unnecessary background processes. grab yourself gamebooster or tuneup utilities and rin them on your system. also you can plug in an sd or usb card and use ready boost to increase ram and catche so some strain will be taken off your system.
hope this helps,
john
just a thought.
hope this helps,
john
geposted Fri 24 Jun 11 @ 5:37 am
Thanks john! I will try all your tips..
geposted Sat 25 Jun 11 @ 10:13 am
not a problem, let me know how you get on and ill help where i can.
geposted Sat 25 Jun 11 @ 2:40 pm
I know this may sound obvious, and forgive me if you have already done this, but check the "config" as updating to pro may have inadvertantly changed your setup/mappings etc. Something weird like this happened when I used my mixtrack on my mates computer and I had to re-choose the "Numark" setting for the audio outs and soundcard, meaning the controller was doing weird things until then.
geposted Sat 25 Jun 11 @ 3:21 pm
