I am wondering if there is a way to lock the volume of the samples, to the mains volume. Ie, i want the sample to play at the exact same volume as the mains. I am using a Hercules RMX, and at times the samples totally overpower the music output. Thanks in advance :)
[Moderation Staff] Signature with links removed. Please post Twitter and/or Facebook links on your Homepage.
geposted Sat 25 Jun 11 @ 11:17 am
What I do is adjust the main volume down a bit. Then you can hear the samples. Another thing you could do, is use a 4 deck skin and load the samples on deck 3 or 4 and you'll have more control. That way you can also use effects on your samples.
geposted Sat 25 Jun 11 @ 11:51 am
great idea!! but no way to directly link the levels? thanks again!!
geposted Sat 25 Jun 11 @ 1:51 pm
if you use the samples in the 4 deck skin you can activate the "auto gain" option in ght config and vdj will do it for you so your volume will always be leveled.
geposted Sat 25 Jun 11 @ 2:56 pm
