Is there an easy way to change the registry to make sure that whenever VDJ starts that the skin isnt automatically Maximized. I am finding I have to always hit the maximize button to turn that off every time I open VDJ??
geposted Sat 25 Jun 11 @ 7:05 pm
Yes, there is a Maximize registry in Virtualdj. The application will open in Maximized mode, if Maximized was enabled by the time you closed the software. If the software closes non-maximized, then it will open again on its original dimensions (resolution).
But not an easy way to change that, as you need to run the Regedit first.
Alternatively you could add a init action to your skin like this..
<init action="maximize off"/>
geposted Sat 25 Jun 11 @ 8:57 pm
