i have a set of numark v7s turntables.... with a denon x1600 mixer.
i have my v7s set up as the form and the video recommends here..
but they still wont work correctly...
okay here is what happens... i switch my mixer on and then i switch my master v7 on and then i switch my salve v7 on.. however on my slave v7 i cannot switch the master button off......... i have tried nearly everything i can off but still they wont work............ its completly void and does nothing.....
sometimes i get lucky and the button will switch off and will work for 15 or 20 mins but then it skips and the master button switchs back on and causes vdj to crash................
any ideas.........
my ticket number is 153025 i have been talking too acw_dj and they have help me alot but yet after about 15 mins boom the decks go down again
i have done everything i can think off please help
Terence
any ideas.........
Terence
geposted Tue 28 Jun 11 @ 2:28 pm
Have you followed your Itch upgrades since you got the units? There are firmware and driver upgrades that only push through the Itch software. First uninstall any Numark drivers and then get the latest Itch version and install it.
geposted Tue 28 Jun 11 @ 5:50 pm
Update...
installed the latest drivers and firmware... and switched on vdj and i just pressed played it work for maybe 30 seconds then boom the computer processor spiked and the controllers froze again
geposted Wed 29 Jun 11 @ 3:28 am
computer specs..
Toshiba
Pentium dual core t4300 @2.10ghz
windows 7 32 bit
4 gig ram
500 gig memo
Toshiba
windows 7 32 bit
4 gig ram
500 gig memo
geposted Wed 29 Jun 11 @ 3:37 am
What settings are you using on the Numark ASIO Panel ? Config -> Sound card tab -> ASIO button.
Give me all your settings from the Performance tab as well.
You are using the default mapping within VirtualDJ ? No custom mapping?
You are using VirtualDJ version 7.0.4 ?
You only have 1 V7 connected via USB and are using the Link cable to the other unit ?
Can you tell me where the switch positions are on the back of each V7 ?
Left Deck ->
Right Deck ->
I know - probably all the same things you have answered with the other guys - but I just want to make sure.
Left Deck ->
Right Deck ->
geposted Wed 29 Jun 11 @ 10:33 am
hey buddy i just pm all my details to you..
geposted Thu 30 Jun 11 @ 2:42 pm
