Ok just trying to figure out how this would work
Numark M6 Mixer 4 Channels
Gigaport 4Chan soundcard
2 turntables
Now My Question is would i be able to still play all four decks and have the turntables hooked up to two channels? would i need another soundcard to have this all connected and running? Or do the turntable RCA cables connect to the mixer?
any help would be appreciated of course
if you have answer please email me becuase this topic mite get lost in the sea of topics
tonyguetterman@yahoo.com
2 turntables
geposted Tue 28 Jun 11 @ 7:00 pm
turntables using timecodes require the ability to send the signal into vdj so you need two stereo inputs, it doesn't matter if they are line inputs as you can ground your turntables on the mixer, then if you only have 2 stereo outputs you can split the outs into mono for 4 individual decks, but your best option is to just buy an NI Audio 8, or similar soundcard as your soundcard has 4 stereo outputs and no nputs from what I can see.
geposted Tue 28 Jun 11 @ 7:31 pm
dang your always answerin man questions thanks man
so if i get that soundcard i can run everything through that??
geposted Mon 04 Jul 11 @ 1:12 am
I have a similar question, but my controller is a VMS4. I have VDJ Pro, so it can "handle" multiple decks.
Would I just need to get the Timecoded Vinyl to use on the TT? Or will I stll need a secondary I/O soundcard?
If that's the case I am not sure how everything is supposed to be connected.
Sorry Tonyguetterman, I dont mean to jack your thread, but I was wondering the same thing, just with a different controller.
geposted Wed 06 Jul 11 @ 12:14 am
@tony, yep the audio 8 will do a great job, but if you can find another soundcard with 4 ins you could use both cards, or an audio 4 would give you 4 decks in total using both soundcards...
@serkle I'm not familiar with the soundcard in the vms4, but if you have a spare 4 inputs you can run timecodes, if not same advice get an audio 4 or similar
geposted Wed 06 Jul 11 @ 4:49 am
