Forum: Old versions
Topic: Sounds Outputs Not Working
Hello All,
I am having problems with the audio from my VDJ. I just recently got a Mixtrack Pro. I connected my headphones into the headphones jack, and connected it into a phono, which is then connected to speakers. The problem comes when i try to play music. When i play a song without CUE, there is no sound whatsoever. The minute i turn CUE on, the song comes though BOTH the speakers and the headphones.
The help would be appreciated and thanks in advance.
Inputs: None
Ouput: Master: Chan 1 & 2 / Headphones: Chan 3 & 4
Soundcard: Numark
geposted Thu 30 Jun 11 @ 9:50 pm
Your problem is most likely because the free home edition of the software doesn't support advanced sound configurations or MIDI/HID Controller/Mixer Support.
Here is a link to a comparison chart: https://virtualdj.com/products/comparison.html
I would suggest buying the software. You would be hard pressed to find a VDJ Pro user who regrets buying a pro license. Besides getting things set up so they work for you, a registered pro license grants you full access to all the plugins, effects, skins, etc. And the best part, FREE UPDATES FOR LIFE! Not to mention these forums are full of users just like yourself. Many will have similar laptop/midi controller configurations to yours. The software developers are here as well, and THEY ACTUALLY LISTEN to us. Go Pro. You'll be glad ya did.
If your Mixtrack Pro came with LE version of Virtualdj, please register that to your Profile Page and download the latest LE version from your Download Center.
Make sure that the Numark is recognized by your OS as a 4ch sound card
Open the sound properties (Windows-Control panel) and configure the Numark speakers as Quadrophonic (Front-rear)
