FYI I am a complete noob. i just bought the Numark Mixtrack with Virtual DJ. I just got it today but did not get the audio interface yet and i don't know if that makes a difference in why it won't work on my desktop.
I was able to install VDJ on my laptop no problem and was able to sync the controller no problem and it worked fine. However whenever i go to install it on my desktop my desktop does not read the Controller. I go to open VDJ and it says that the controller is not connected to a USB port when it is. I have tried multiple USB ports to no avail.
I have tried to find any drivers that would help fix the problem but was unable to after searching quite a bit and was unable to get in contact with any customer service because i am on the west coast and they were all closed when i got the package.
Any help would be appreciated. cheers
geposted Fri 01 Jul 11 @ 1:32 am
register your serial so you can update your copy of VDJ to the latest version, and the mixtrack will be natively supported
geposted Fri 01 Jul 11 @ 1:34 am
so i downloaded the most recent version of VDJ LE and now i am able to open the program on my desktop but the controller is still not being read by the program.
When i go into the setup section at the top right of the program the input section i greyd out and i am unable to select anything. Is there where i have to select the controller? My computer recognizes the controller fine and says all the drivrers are installed and up to date so i don;'t know where to go. Of course tech support is closed by the time i get out of work...
geposted Fri 01 Jul 11 @ 7:54 pm
