First off...I love this lil thang! A nice step up from my RMX!! One thing though, can one of you mapping pros show me how to change one setting:
I want to reverse the way the jog wheels function when you rotate them to adjust the pitch. Right now if you rotate counter clock wise the song slows down, and clock wise it speeds up. I wanna flip that! Any help is greatly appreciated!
Been trying on my own to figure this out but with no luck! Thank goodness for that factor reset button on the mapper!! ;)
geposted Fri 01 Jul 11 @ 3:15 pm
i have to ask... why?
I can help if you paste one of the original scripts for any button/fader...
geposted Fri 01 Jul 11 @ 5:31 pm
The wave forms move from right to left and my hands want to turn the jog wheel in the direction that the wave form is moving, either to catch up or slow down. I know I shouldn't even look at them, but I do! What button scripts would you like for me to paste? Thanks.
geposted Fri 01 Jul 11 @ 7:51 pm
I strongly recommend that you get used to playing the standard way (CW) because what will happen if you play a set in a club that only has cdj 1000's (which most do), I recommend that you turn the wavform off and you just learn to mix with your ears... I used to have to tape up my eq so I didn't rely on it when learning to beatmatch, because honestly, before I trained myself to have more discipline with my senses, if i was focusing on my sight I couldn't hear properly enough to mix...
What you might be able to do is reverse the waveform, what skin d you use, hopefully a skinmaster may be able to help
geposted Fri 01 Jul 11 @ 9:47 pm
