Ever since starting to use the NS6 and the 4 Deck skin (3-1-2-4) I am getting very high CPU usage. Usually floats around 40-45% but when loading a song I'm going around 95%.
Before using this setup I was only getting around 10-15% of CPU usage and approx 75-80% when loading songs with my RMX and two deck skin.
This is the MAC setup, any ideas? Is this normal to run that high with a 4 deck skin?
geposted Sat 02 Jul 11 @ 7:02 pm
make sure the skin is in the same resolution s your screen or you haven't maximized it
geposted Sat 02 Jul 11 @ 10:26 pm
SKin is same resolution as screen but I do run it in maximized mode. Will give that a shot.
geposted Sun 03 Jul 11 @ 8:36 am
Have you scanned your database prior to loading said track? This can be a characteristic of a maximized skin (not recommended) and/or an unscanned track prior to loading.
geposted Sun 03 Jul 11 @ 10:29 pm
I'm going to go back and rescan it just to make sure. I thought all was scanned but may have added a bunch of new stuff and forgot to. Will check and report back. Thanks
geposted Sun 03 Jul 11 @ 10:31 pm
No Dice! I rescanned last night but did not help. I have shut down all unnecessary background processes with only VDJ running. No other applications running. SItting idle i'm running at about 30% cpu usage not even doing anything. moving the mouse cpu usage goes up another 10%.
I'm not sure what happened as this only used to read about 10% cpu usage but now seems to be eating resources.
geposted Mon 04 Jul 11 @ 7:48 am
probably a silly question but have you tried any other skins in the same resolution? did you still get high cpu usage?
geposted Mon 04 Jul 11 @ 8:48 am
The Numark drivers are notorious for running heavy on processing. If you are below 50% then that is good. Having a spike above 75% on loading a track is also not uncommon - specially if you have 2 decks already playing and loading a third deck.
geposted Mon 04 Jul 11 @ 9:49 am
Merry Christmas to all, hey i know this is a old posting, but I'm having the same issue with high cpu usage mine is at 80-100% before i plug in my RMX, in your answer you said to rescan? what is that? hope i don't sound too simple. i have my laptop wiped and reloaded, to open more memory, if i CTRL+SHIFT ESC my cpu says 14% but vd cpu says 80%. im only using 2 deck skin
geposted Sun 25 Dec 11 @ 9:00 am
Yes... What does rescan mean? Is that when you run a BPM scan on your tracks?
geposted Mon 26 Dec 11 @ 4:55 pm
Yes, bpm scan - rescan
geposted Mon 26 Dec 11 @ 7:25 pm
