Forum: VirtualDJ Skins
Topic: NS6 SKIN - Page: 4
Please 1366X768 too..
Hi Rodrigo, love the skin and it works great with my NS6 but it would be even better if you also add 1600x900 for native support for my notebook. I tried using the skin resizer tool but the digital turntables get skewed/warped because of the slight offset in size.
Keep up the good work
hello,
any news for the 1280 x 800
if you need it to test, i can do that....
thank you and all the best for 2012!
Hola, en donde lo puedo descargar?
for obtaining skins you must have purchased a license broadcaster, basic pro or pro full access to this and many more tools available, you can see the range of products here, greetings.
https://virtualdj.com/products/comparison.html
para la obtencion de skins tienes que haber comprado una licencia broadcaster, pro basic o pro full para tener acceso a eso y muchas mas herramientas disponibles, puede ver la gama de productos aqui, saludos.
sorry for write in spanish
its an amaizing skin but virtualdj.com has an error that says it can't find the website and to try later and i can't download it... noooooo:( is there any other way to download it???
I don't know what I've done wrong, but I posted the same link. It works for me too.
Hey I am having an issue: when the screen shows one deck playing, it controls the other deck. For example: I see deck one on the screen, but when I do anything on the NS6 (press play for example) it loads and controls Deck 3. Any idea why?
Hi Ro,
Any idea when we can have video support on this fantastic skin?
Thanks
Johans
johans wrote :
Hi Ro,
Thanks
Johans
Soon.. maybe for the next month
dJ_ro_(ecu) wrote :
I\'ll be releasing this skin are the later on this evening or tomorrow.. Should be available over the weekend hopefully.
More Preview (4 Decks)
porque no puedo descargarlo porque me dice que no tengo licencia ? una esplicacion porfavor
Heh o great NS6 creator, thanks for the wonderful skin, absolutely love it!
A question though please, is it possible to mod it do the sync buttons on the ns6 work as 'play_sync_onbeat'.
I mean for me to do it btw, I'm not asking you to do it. I just want to know if it's possible.
Thanks to you !
I sorted it via the mappers section in config
Could anyone pls tell me if the Master Deck should change automatically during a mix or if that needs to be done manually.
Mine is not switching automatically, and if that's the way it's meant to be that's fine, but if not that I need to figure out why.
If its not I may try mapping it to switch between 1 & 2 with the VIEW button on the physical NS6, as that does not appear to be mapped to anything.
No one?
The thing is that it only occurs on this skin and not the default 4 deck skins so i thought this would be the proper place to ask. As for the link you provided and the fix in that post, it is set correctly already and still does not auto switch.
From the thread (link) above, look at the 5th post..choose solution a.
67%
