Hey folks,
I have 2 Hercules RMX controllers, a macbook pro and Virtual Dj pro full 7. Does anyone know how i can set it up to use both controllers to control 4 decks. I.e controller 1 controlling decks 1 and 2 and controller 2 controlling decks 3 and 4. Any help would be much appreciated.
Cheers!
Cheers!
geposted Sun 03 Jul 11 @ 4:31 pm
you can control four decks with one controller. All you have to do is use a 4 deck skin and map a button on the RMX to switch decks from 1 to 3 or 2 to 4.
I ran 4 decks with my RMX before not difficult at all.
As for using two RMX's I'm not sure thats even possible since VDJ or any software really, looks for A single controller.
geposted Sun 03 Jul 11 @ 10:35 pm
You can use 2 RMX's, just go into the mappers tab and assign which decks you which RMX to control.
Good Day
Huey
Good Day
Huey
geposted Mon 04 Jul 11 @ 1:16 am
And I forgot, you might have to go into the RMX control panel and switch the MIDI channel for 1 of the RMX's.
Huey
Huey
geposted Mon 04 Jul 11 @ 2:46 am
