Hello all,
I was considering getting 2 Denon SC2000's.
Can VDJ-users of those controllers report about their experiences please, be it under Windows or Mac.
I saw 1 thread about possible freezing, but the thread went silent ...
https://virtualdj.com/forums/143759/Hardware_Technical_Support/Virtual_DJ_freezes_with_DENON_DN-SC2000.html?search=sc2000&page=1
Thanks so much in advance.
Best,
Arie
Best,
Arie
geposted Sun 03 Jul 11 @ 4:46 pm
Hello all,
"... it's the sound, of silence ..."
Any experiences out there, that can be shared on this topic ?
Thanks in advance,
best regards,
Arie
Thanks in advance,
best regards,
Arie
geposted Mon 25 Jul 11 @ 6:03 am
New firmware has been posted by Denon Europe, it seems to have solved the freezing problem for Traktor's so far nobody has reported results with VDJ
http://www.dm-pro.eu
geposted Tue 13 Sep 11 @ 1:49 pm
Testing now.. Fixed it in VDJ, too looks like. Works great, so far. No more jittery pitch fader. Takes time to experience the freezing. Will report back later.
geposted Tue 13 Sep 11 @ 8:42 pm
Hi Guys,
sounds like great news & I would like to thank you, for keeping me up to date about this !
Please let us all know, as soon as you have further findings.
Thanks again,
best,
Arie
Thanks again,
best,
Arie
geposted Wed 14 Sep 11 @ 3:11 am
Hello, I need a bit of help or advice..
I am bored with the vinyll and cdj setups and have mastered beatmatching many years ago and would now like to evolve more onto live remixing by applying cue points and layering beats etc.
I am considering this type setup and need to know if this would viable or if there is something better out there for me now or in the near future...
I'm thinking of getting a pair of Allen & Heath Xone K'2's and connecting them up to my external Vestax PMC280 4channel mixer so that the lefthand side K2 controls channel 1&2 and the right hand side K2 controls channels 3&4 on the mixer and VDJ respectively. as seen on:
http://www.allen-heath.com/Assets/Pages/videoplay.aspx?FileId=http://www.youtube.com/v/IgU-eesd6hI
In addition to this, I would also like to add the DenonS C2000, reason being, i like the jog dial and dedicated pitch control, cue and play buttons..
Now, I would like to know if it would work if I map/use the Denon to control the jog, pitch,cue and play functions on all 4 channels?{i.e on the Denon deckA(blue)controls channel 1&2 and deckB(red) controls channel 3&4 within the mixer and software?
Thus giving me jog, cue, play, pitch control and all K2 functions over 4 Channels?
geposted Thu 07 Jun 12 @ 3:48 pm
Each SC2000 has two layers (RED+BLUE)
Out of the box it will work as a 2 deck controller. You can use some "advanced" scripting and make it work with all 4 decks if you wish, but not out of the box.
geposted Fri 08 Jun 12 @ 2:25 am
If you have two SC2000's, then you can assign the first to control decks 1&2 and the second to control decks 3&4 (Because each is effectively a 2 deck controller.)
geposted Fri 08 Jun 12 @ 5:48 am
