Still think you may need a better quality splitter, try a store that has a returns policy.
geposted Tue 05 Jul 11 @ 6:23 pm
If your splitter is not amplified it will not work, I have an amplified splitter and powered 6 monitors and one projector all night long with no problem.
This is what I use http://www.bhphotovideo.com/c/product/476206-REG/SIIG_VV_S80012_S2_VGA_8_Port_Video_Splitter.html
I use my unit every week for the past two+ years...
geposted Tue 05 Jul 11 @ 6:59 pm
I would agree with this. I think you need something with an amplifer similar to this: VGA SPLITTER WITH AMPLIFIER
I use something similar to this and run two two monitors with a 150' VGA cable to the front of the church. Running 4 LCD TV's with the same type setup.
geposted Tue 05 Jul 11 @ 7:01 pm
I am having Tiger Direct replace the powered splitter. That is what I purchased and what the link in the earlier post shows. Something may be wrong with it though because it's hard to turn on. I have to hit the power button several times for it to turn on and stay on.
This is a short video of what I'm experiencing.
http://www.youtube.com/watch?v=X40oYIvcDWk
This is the product I have and Tiger Direct is replacing.
"SABRENT 4-Port VGA Vider Splitter"
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4266222&CatId=466
geposted Wed 06 Jul 11 @ 7:56 pm
I can't see your youtube video for some reason....
geposted Wed 06 Jul 11 @ 8:16 pm
The link should work. I tried it and was able to view the video. Try again.
geposted Wed 06 Jul 11 @ 8:27 pm
This is all I get when I click the link you provided..
geposted Wed 06 Jul 11 @ 8:36 pm
I can see your video just fine ....
What resolution do you have the 2nd Monitor output set at ? What happens if you choose 800x600 or 1024x768 ?
It looks like a refresh frequency issue.
geposted Wed 06 Jul 11 @ 9:43 pm
City, did you try to move this thing away from the power cord? I noticed in the video that the VGA cables was lying on the power cord or two. This will cause interference a lot of times especially with VGA signals.
geposted Wed 06 Jul 11 @ 9:45 pm
I have the same splitter from TigerDirect and I am having no problem with it. I have it running to my 2 Vizio 32" LDC TV's. Maybe you have bad VGA Cables or a bad Splitter (more likely) as my splitter is real easy to turn off and on?
geposted Wed 06 Jul 11 @ 9:53 pm
Ok, djcity I also have the same dell monitor you have and set it at 1024x768 for it to work properly....
geposted Thu 07 Jul 11 @ 9:29 am
I received my replacement splitter today and will test it this weekend.
I HOPE all goes well. I will report back to you all with the results.
geposted Fri 08 Jul 11 @ 5:26 pm
Here are the results.....
No Good.
New splitter that turns on and off with no problem but I still have the waves on the screen. My next test is gonna be me setting up everything at home and testing it with MY tv.
No Good.
geposted Tue 12 Jul 11 @ 4:37 pm
Florescent light fixtures creates an electrical force field and will cause an adverse effect on monitors and electronics...Try setting up in a new area.
Also an outlet filter will help get rid of bad signal feedback through the electrical source...
Good Luck,
Joey...
Good Luck,
Joey...
geposted Tue 12 Jul 11 @ 5:00 pm
