When I change the active deck and select deck to deck 1 (you can see the lights move), the vms4 jogwheel, etc will only control deck 3. Is there a way to toggle control so all the vms 4 controls work for whatever deck is selected?
Using dj dad latest mapper and standard 4 deck 1280X768 skin.
geposted Mon 04 Jul 11 @ 8:53 pm
The Pitchbends do the job you need.
Left side..
Pitchbend - makes the left side of the VMS4 to control deck 3
Pitchbend + makes the left side of VMS4 to control deck 1
Rightside
Pitchbend - makes the rightside of the VMS4 to control deck 2
Pitchbend + makes the right side of VMS4 to control deck 4
just like the deck order 3,1,2,4
Left side..
Rightside
geposted Mon 04 Jul 11 @ 9:44 pm
Thanks for quick response but that wasnt it. Went back to original mapping and still wouldnt work. Turned out to be something in my dicers over riding things. Not sure what yet but when I unplug the dicer, everything works correctly.
Thanks heaps for your work on the mapper - has helped me heaps. Can go back to my minor mapper adjustments (I like pitch bends haha ;)
geposted Mon 04 Jul 11 @ 9:48 pm
For anyone whos interested, this problem was created by the dicers wanting to control decks 1 and 2 and the vms wanting 3 and 4. If you go into config/mappers and click the wee button next to the name, you can select from a drop down list and change both vms and dicers to use 'left and right' instead of specific decks.
geposted Tue 05 Jul 11 @ 3:12 pm
