I have a MacBook Pro, Mixtrack deck and the version of Virtual DJ that came with the deck. For some reason I can't cue using the headphones AND use the computer speakers as monitors. I have two sets of headphones. One set is USB wireless with a mic and the other plugs into the mic and headphone jacks on the computer. I either end up having to cue and mix using the computer speakers or the headphones. I am used to doing both. What am I doing wrong? I read somewhere on this forum that I need a "Y" splitter for the headphones.
In the case of my headphones (described above), how would that work?
Thanks in advance and I apologize if this has been discussed before. If it has, a link to the discussion would be much appreciated.
geposted Tue 05 Jul 11 @ 12:29 pm
Nevermind. I think I found an answer
geposted Tue 05 Jul 11 @ 1:23 pm
