i want to remove the last plugin cause its buggy...how can i do this w/o having to reboot the vdj itself ie..uninstall / reinstall?
geposted Tue 05 Jul 11 @ 1:11 pm
Go to your plugins folder and delete the ".dll" file. C drive/my documents/Virtualdj/plugins/sound effects
What plugin is giving tu problems??
Huey
Huey
geposted Tue 05 Jul 11 @ 1:21 pm
the new numark ns6 effects working
geposted Tue 05 Jul 11 @ 1:28 pm
that dl file isnt in the plugins...where else might it be..ive looked thru the folder...did i miss it?? ty for your help..greatly appreciated..ive actually got a day to mix and it starts actn up
geposted Tue 05 Jul 11 @ 1:33 pm
You should probably ask in the NS6 thread, Cstoll is able to offer more help when it comes to that unit then I can.
Good luck and sorry I couldn't be more help
Huey
Huey
geposted Tue 05 Jul 11 @ 1:42 pm
It's a mapping not a plugin, so should be an xml file in your mappers folder. There might be a corresponding one under devices too.
geposted Tue 05 Jul 11 @ 3:15 pm
In your virtualDJ folder there should be a folder named "Mapper" open it and look for a NS6.xml file, that is the mapper for your controller, delete that if you need to reinstalle.
Good Luck,
Joey...
Good Luck,
Joey...
geposted Tue 05 Jul 11 @ 5:00 pm
ty so much ...ill give it a shot
geposted Thu 07 Jul 11 @ 7:40 pm
