Hi I have VirtualDJ 7.0.4 and am using vms4 and have tried loads of different setups and the decks on the controller are the wrong way round to the screen. Has anyone else had this and does anyone know how to change it?
I have updated the firmware on the VMS4 and.
The rest works all ok but the desk are just the wrong way round!
Can someone help me please?
Thanks
Austindj69
UK
Thanks
Austindj69
UK
geposted Wed 06 Jul 11 @ 4:47 am
The Deck order in the mixer by default is 3,1,2,4 Left side of VMS4 controls decks 1 and 3 and the right side of VMS4 controls decks 2 and 4.
Do you wish the order 1,2,3,4 in the mixer? Do you also need to change the decks in control?
geposted Wed 06 Jul 11 @ 4:56 am
Hi
I have just found the answer on another post for another controller.
I also have 2 Radius 3000 connected too so can use CD or 4 decks on VDJ7 if you press eject button on the Radius it switches the decks over.
All sorted now hope this may help anyone in the future that has a doh!! moment.
regards
Austindj69
regards
Austindj69
geposted Wed 06 Jul 11 @ 5:01 am
