I originally had this problem when I loaded a song in to a deck as soon as I pressed the play button it would start out blazing loud with the volume control down. I kinda fixed that problem but still getting it with some tracks that I recently added. I've added all
My songs to the data base but if it's a song I never played yet I have to crank the volume nob all the way up real quick and then I have control over the volume is their a way I can get rid of this issue or fix this problem?
Thanks in advance
DJ SteveO
Thanks in advance
DJ SteveO
geposted Wed 06 Jul 11 @ 11:54 am
You have to scan your tracks first, adding them to the database is just that, you add them. But you still have to analyze the tracks. Right click and hit the bpm.
Huey
Huey
geposted Wed 06 Jul 11 @ 12:01 pm
Each time I add new music or videos to my music library,I take time to load each song/videos and set the cue point and re-analysis,make notes & ck the BPM/adjust gain if need it,before I go do a set.I also delete all song under 2:00 minutes.
geposted Wed 06 Jul 11 @ 6:53 pm
Huey
Huey
Will try that Huey I know it's going to take alot of time scanning 10,000 songs.
geposted Wed 06 Jul 11 @ 9:35 pm
Start off scanning the tracks you need now, if you need one that hasn't been scanned make sure its fully loaded before you press play and you should be fine.
Good luck bro
Huey
Good luck bro
Huey
geposted Wed 06 Jul 11 @ 10:24 pm
I can't believe you have that many songs that have not been analyzed. Recourse the drive, which will show every track on the drive. Select bpm so that all the analyzed tracks are together. Highlight all unanalyzed tracks, and analyze over night.
geposted Thu 07 Jul 11 @ 11:40 am
That way works great but what I've found is that some of the tracks I buy have the bpm in the id3 and they'll show up with the bpm. Kinda like they have scanned already. Best bet would be to setup a filter folder like this,
"Isscanned=1" or "Isscanned=0"
Then when ever you add new tracks to the database they show up there. Next do the right click thing and scan your tracks.
Good Day
Huey
Good Day
Huey
geposted Thu 07 Jul 11 @ 12:34 pm
