Hi all, i am working on a new mixtape and would like to transfer the tape into VDJ Home, and mash it up a bit.. its all working in real time, but when i go to record im lost i dont know where it is recording to ?
geposted Thu 07 Jul 11 @ 1:36 pm
Above the recording button there is a smaller button that says "settings", just click there and a configuration window will pop-out. Once you are in there it gives you the option to where you want the mix to be recorded to. Just select where you want it to record it to, example: My Documents. Once you finish just go and look for it!
Btw just to know, what do you want to do to the mix in Virtual DJ?
geposted Sat 09 Jul 11 @ 1:12 am
