Could someone point me to a guide on setting up VDJ with a Rane SL1? Trying to get it working on a rig with a pair of CDJ-800's.
Strangely enough, if you search the forums for "SL1" you get no results, even though I know I've seen it talked about here.
geposted Sat 09 Jul 11 @ 7:55 pm
Set it up just like the picture but replace the turntables with cdjs,
You probably won't need to hookup the thru outputs because you can just use the timecode bypass button on the skin to play real records.
Hope that helps and enjoy
Huey
Huey
geposted Sun 10 Jul 11 @ 2:00 am
Thanks,
I was looking more for instructions setting up VDJ to use the SL1 hardware, but maybe that's easier than I'm anticipating.
Guess I'll find out when I get to the club!
Thanks...
Thanks...
geposted Wed 13 Jul 11 @ 6:35 am
This is how youd set it up..........you might have to click on the 'timecode config' button and adjust things so you get a perfect circle, but its pretty much just like if you were using Serato.
Good Day
Huey
Good Day
Huey
geposted Wed 13 Jul 11 @ 7:17 am
I think they disabled 3 and less character searches recently which sucks looking for keywords like SL1, RMX, MK4, NS7. I cant find s**t.
-David
-David
geposted Wed 13 Jul 11 @ 8:48 am
