I have the home version on my tower PC and it works just fine. All the info shows up perfectly from the songs in my Music folder. However, I just loaded it onto my new laptop and it only shows a smattering of artist info here and there on the browser window. If I do a search on a particular artist, it will display the songs listed by that artist and that artist's name will then show up in the artist field. It's just that the artist's names don't show up in the browser field upon booting up. Any ideas?
The laptop is a new Gateway with a 3.10 Dual core processor, 3 gig RAM and 284 GIG Harddrive
Terry Sumner
Terry Sumner
geposted Sun 10 Jul 11 @ 10:29 am
You will need to add the music to your VirtualDJ database for it to appear when searching.
To do this, use the VirtualDJ browser to browse to the drive(s) and/or folder(s) where the music is located, right-click on the folder and choose Add to search DB.
Also, make sure that all your files are tagged correctly with the correct artist, title, etc. and named in the standard format of: Artist - Title
geposted Sun 10 Jul 11 @ 1:08 pm
